tuners
Old Sep 22, 2011 | 05:20 AM
Code Red Monte's Avatar
Default tuners
so in the past ive tryed many ideas on pcms for hte ss, but to most ive run into either bricking the pcm or can not write to it or pcm is not able to take the tune due to wrong hardware, ive been looking at a hp tuners set up and wanted some other ss guys that are tuned out there on what they have run into in the past while tuning and what style or version of tuning software they have used. thanks code red
Old Sep 22, 2011 | 01:06 PM
z34phoenix's Avatar
Huh? what tuner are you using that is bricking PCM's? a Powrtuner? if the drivers arent set right for the serial adapter, netframe 1.1, and jet 4.0 arent setup correctly you will have issues. also it says if you have office 2003 you could have issues. all of this is solved with having a laptop solely for tuning.
If your trying to tune your 2005 then that might be where you are having issues. only the last few powrtuners were set to tune 04+ IIRC. i know i have a early to mid gen PT and i dont think i can upload to the 05's i think most who tune them are using HP tuners like you have said.
and what are these "many ideas"? sounds iffy....
Old Sep 22, 2011 | 02:10 PM
I always read that you should just do partial writes. Change one small thing, flash it back, change another, flash it back. Not make huge changes and then write the whole thing at once.
With that said, my car is tuned with DHP, but it was done by a friend.
Old Sep 23, 2011 | 12:28 AM
ok, well most time if i did a write and it brciked it was off board due to me trying to get a modified DBF via powertuner. and other ideas i was only looking for info from guys that have had to get around the security messures on the pcm.
Old Sep 23, 2011 | 10:34 AM
Enzo354's Avatar
STILL SLOW
Yea HP tuners is much more stable.
Old Sep 23, 2011 | 09:33 PM
Ya I emaild dhp and got a semi auto response to my question but still. I quess I'll look into other ideas like a zzp or 3800 performance PCM . Thanks
Old Sep 23, 2011 | 11:01 PM
Wilco's Avatar
your best bet is to go with hp tuners. it won't give you all the flexibility on a v6 as on a v8 but its a more stable software than what's out there. It's not a cheap program but its very much worth it.
Old Sep 23, 2011 | 11:41 PM
HP tuners is good, i used it before
Old Sep 24, 2011 | 04:23 AM
now on the hp tuner you can get past the security messures on the pcm right? most time i cant write to it due to the pcm being locked.
