Tune up?
Can you tell me when to consider if I should need a tune up or not?
Tune ups consist of things like:
- New plugs - New plug wires - Replacing the fuel filter - Replacing the air filter - Flush the coolant (which should be done fairly often before a "tune up" interval) If you are at or near 100,000 miles on a modern Monte Carlo, yes you should consider these things. GM normally gives a suggested maintenance schedule with these cars. If you still have it, that guide usually won't steer you wrong. |
