trouble starting
Old Dec 27, 2008 | 08:25 PM
StanzManianDevil's Avatar
Default trouble starting
wen i turn the key it just lays on the starter for liike 8 sec just tryin to kick over then when it starts its real dim and has a low rpm.. its an 02 ss with only 40k on it .. any ideas of what it can be ?
Old Dec 27, 2008 | 08:33 PM
mrl390's Avatar
Default RE: trouble starting
I would start with the simple. Do a tune up if you havent in a while. Plugs and wires. Check the fuel filter. If its the original one it may be clogged.
Old Dec 30, 2008 | 10:32 PM
its fixed.. it was the fuel regulator
precious1979
Dec 12, 2012 08:12 AM
Val1970
Oct 25, 2012 04:14 PM
70monte1
Dec 7, 2010 09:12 PM
Pineapple
Nov 24, 2007 04:14 AM
01pacecaredition
Jan 5, 2007 02:36 PM
