gearhead65 |
03-22-2017 03:54 PM |
Transmission troubleshooting
So, I have my '99 Monte parked for awhile now cause I think the transmission is on it's way out. But some of the symptoms are kind of unusual. Hopefully somebody can help me out here and hopefully it doesn't require a full rebuild.
So, when taking off in first, it slips really bad for awhile until you get up to speed and then it's fine. But when you come to a stop, it slips again when you take off. If I reverse and hit the brakes hard to stop, when I go back into drive, it takes off just fine until I stop again. Wierd right? Reverse initally worked fine but seems to be slipping now too. I've changed the fluid and filter, but no change. Any help would be appreciated.
