throttle body wiring info
85 monte 4.3. I twisted idle control valve off in throttle body so I need to remove it. I'm to the wiring. Do the wires, 2 on each injector simply pull out after uncoupling the retainer?
https://cimg7.ibsrv.net/gimg/monteca...ea540671ea.jpg |
Okay they do pull out but I now see they aren't supposed to. Hope I can get them back in lined up.
The wires simply push back on the TBI . You might have to pinch the two tabs on top of wires and it should push right on .
