swapping an engine into my 2000 Monte Carlo ss. what is needed to fit a 2006 5.3 to f
what is needed to fit a 2006 5.3 into a 2000 Monte Carlo ss
You're going to need a lot of parts than just the engine. You'll have to rewire the 2000 to accept the engine harness and connectors from the LS4. You'll need to run the gauges and everything from it too.
Here is a thread that details someone who did the swap: https://montecarloforum.com/forum/en...per-ls4-26283/ My recommendation is to get an L67 out of a Grand Prix or 04/05 Monte Carlo and use that engine. |
engine swap
what would be all needed to swap out to a l67.what years tyvm in advance. im new to this
it was a 3800 n/s engine
Originally Posted by nnightrider
(Post 715888)
For the L67 you would just need the engine, and wiring harness (or you can adapt your L36 wire harness for the handful of sensors that change)
And you would also need to get your PCM tuned for it. 98-02 Grand Prix 04/05 Monte Carlo / Impala SS |
If you're serious about a LS4 swap, I'd buy a whole wrecked car. If you just buy an engine, it's going to be a pain to get all the stuff in place to make it run made worse by the fact that you're going to be hard pressed to find one at all at a local junkyard to pull parts from.
At least by getting the whole car, you know you've got everything to make it run & drive. But I do agree, I'd just L67 swap it. |
I wanna see the V8 swap!!
Betting the mechanical swap would be the easy part , swapping fuel , cooling system, suspension and electrical is where the nightmare would start. I would think it would be cheaper just getting a V8 car. Yes that just came from me .
Done!!!!!!! I completed my LS4 swap in 2011 and its even Cali Legal (Smog)
https://cimg9.ibsrv.net/gimg/monteca...707eec4c96.jpg |
Originally Posted by DreddRaider55
(Post 726082)
https://cimg9.ibsrv.net/gimg/monteca...707eec4c96.jpg Hell yea man! Any videos or swap tips?? |
