Is this swap possible?
ive got a 2005 LS 3.4l LA1 V6 with roughly 93,000 miles on everything. Is it possible to take that engine out and put it in a 2002 SS 3.8l L36 v6 ? the ss engine is shot and needs to be rebulilt buts in much better shape than the 05. ive read its a diffucult job but how hard is it actually??
thank yiy |
It's all a very common swap. And if you have both cars, you have all the parts you need. There should be a lot of info on this topic between Monte/Impala/Grand Prix forums.
Without having researched it, the logistics of what you need to do should not be too tough. I don't know if the 3.4 vs 3.8 subframes differ at all (that is my biggest question about the swap). |
It should work, you'll just need everything (engine, transmission, wiring harness, PCM, axles) and you may need to modify the wiring harness, but I'm not 100% sure on that one.
Subframe is the same, with both cars it’s 100% doable. But if you’re going to do that much work why not go for an L67? Unless the L36 car is already yours.
