Spark Plug Wires....
ORIGINAL: ExplosiveSoundz
I was gonna go with the TR6's.
As per ZZP:
For a colder spark plug we recommend the NGK TR6 or TR6ix. These plugs will help to lower KR. New plugs will also increase the performance and gas mileage of a car with used plugs. Many people run TR55's but we have found no ill effects of running TR6's and they work better for getting rid of KR.
As per ZZP:
Yah, actually Dan, the hardest question about spark plugs is what to gap my TR6's to... I have heard .52 for 3.4 pulleys, but I have also heard .49 is great for anyone at a 3.3 and below...So I'm still reading up on where I wanna be on gapping my plugs..
Also, thanks for the clip! I decided not to bleed the two clips together, but you can check them both out at the site, and let me know if you would like any changes!!
-Keegan
-Keegan
tr55's are just the stock plug, dont you need to go to a tr65?? i have tr65ix (which are iridiums, but if i shouldn't run iridiums i will return those)
ORIGINAL: wiz kidd
I actually copied a write up that explained this last week so you would have missed it.
Here is the link to it: http://www.oqcgp.net/phpbb3/viewtopi...44&t=37942
Great article... For only 12 bucks, I think I may just end up getting both the AutoLites, AND the NGK's, and running my Aeroforce scanner to see which one REALLY DOES reduce more knock retard
Thats the beauty of buying those scanners... Now I only have to wait a month to install them
Thanks for the advice and references guys! I think I'm gonna buy these, but will hold on to the stock just incase
-Keegan
-Keegan
I thought the NGK TR55 were iridium, but I remember I have the TR 55ix which are.
Isn'tthe 10.4 MM wire over kill ? Like a race only thing ? I like them though.
I've have been looking into these also. http://www.crateenginedepot.com/stor...Sets-C127.aspx
And they are 8mm thats pretty good, no?
ORIGINAL: Mac7504
I do the same thing with my house. - Home wiring is rated at 14 gage so when I rewired all this 1950's era wire I upgraded it to the thicker 12 gage. It was harder to run than the 14, but I don't have to EVER worry about the wire overheating because of amp draw. the 20 amp will easily blow before hand.
