Series 3 swap
Keep in mind that if you don't swap in a Series II throttle body, you will need to also convert the gas pedal for DBW. Easiest way is probably to either swap in an 04+ GP pedal assembly or an 06+ Monte or Impala pedal assembly. Should bolt right in so it probably wouldn't be a huge deal to do.
A Series 3 engine N/A is exactly the same as a Series 2 N/A from a mechanic stance with exception of the drive-by-wire throttle body and cast aluminum UIM. From what I've read, the internals are more durable (forged vs cast is what I've read).
To swap it into a Series 3 into a Series 2 car, you will have to look at that following:
- Either switch the aluminum UIM for a nylon Series 2 UIM and Series 2 throttle body (direct swap, the LIM is the same between the engines). OR adapt and L67 throttle body to the cast aluminum UIM.
- You may also have to swap some sensors over and fuel rail/injectors from the Series 2 engine to the Series 3.
I'm on a Bonneville forum a bunch and a lot of those guys have pioneered this swap. It's no big deal from all the reading I've done. Require NO PCM changes unless you are modding the engine.
Now to swap it into a 3400 powered car, it's much the same process you would need to do to swap a L36 into it. You need wiring harness, PCM and some other pieces and parts. Personally, if I was to switch a 3400 to a 3800, I'd go Series 3, it's newer, hopefully easier to get a low miles one and has a rep for being equal with only a couple improvements.
I can get the upper intake, injectors, wiring harness and computer for less than $100 from a junkyard. And considering that I am getting a fairly low mileage engine and transmission still bolted together for $600, I think it's a pretty good deal.
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
nebstewart07
Apr 22, 2010 08:56 PM
