-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Scanner? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/scanner-9770/)
Submariner Jun 12, 2008 06:39 PM
Scanner?
I'ma total newbie when it comes to scanners so I need help. Is this the kind I want? The reasonI'm looking is my next mod will be a smaller pulley and everythingI've read here recommends a scanner to check for KR.
http://cgi.ebay.com/Automotive-Scann...QQcmdZViewItem
kweef Jun 12, 2008 07:17 PM
RE: Scanner?
well ive never even heard of that scanner and i didnt read anywhere that it has the ability to reprogram your pcm...i know its expensive but i would suggest an hp tuner...its costly but there are so many things u can do with it...or send ur pcm to a company like zzp performance and have them retune it
Submariner Jun 12, 2008 07:41 PM
RE: Scanner?
ZZP did my PCM. A search of this forum mentioned a Palm scanner so I was curious if this was the same. The search also mentioned you should check for KR. Also I did e-mail ZZP listing all my mods and asking what they recommend for a pulley size. Lastly good point about not being able to adjust settings.
kweef Jun 12, 2008 07:46 PM
RE: Scanner?
yah from what i understand u can monitor everything but not reprogram anything and therefor not change ur settings for the smaller pulley
