6th Gen ('00-'05): Rpm Fluctuation
Old Sep 30, 2012 | 11:49 PM
Chief Monte's Avatar
Question Rpm Fluctuation
Hey guys here's my issue: When my Monte is idling the rpms fluctuate pretty badly. So much that the car jerks forward when the car is in drive. The computer is also throwing a lean code. I replaced the MAF about a year ago. Fuel Injectors maybe? Any input will be greatly appreciated.
Old Oct 1, 2012 | 01:03 AM
01 Monte SS's Avatar
My first guess would have been the MAF, but if you've replaced it, it can't be that lol.
Not sure what would cause such a fluctuation. I know my Monte fluctuates a little. How much does it change, RPM wise?
I'd probably start with new plugs, wires, clean the throttle body up, clean the MAF sensor, even if it's newer. Sometimes a dirty MAF can really mess things up.
Old Oct 1, 2012 | 07:42 AM
03SSLE's Avatar
If the engine is running lean I'd do a fuel pressure test - both at the schrader valve and the fuel filter. That way you can verify proper pressure being delivered from the pump and the regulator. Another quick test would be to pull the vacuum hose off the regulator and check for fuel. If fuel is present in the hose then the regulator is bad. If pressure is acceptable and the regulator is okay I'd check for a vacuum leak.
squidward
Oct 24, 2023 02:28 PM
brockafella
13
Feb 25, 2009 10:54 AM
Revitupfaster
May 8, 2007 01:28 AM
Visual7
Aug 29, 2006 08:50 PM
BeachBumMike
Apr 20, 2006 10:54 AM
