-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Replacing Bent Rod (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/replacing-bent-rod-38479/)
04chevyboy Aug 23, 2012 11:03 PM
Replacing Bent Rod
Is a bent rod the end of the motor or what is needed to be done to get rid of this problem.im find gp's cheap that have bent rods an i could handle the task myself as long as it does not requier pulling the motor,any help would be great,thanks!
Budsjlm Aug 23, 2012 11:51 PM
You would have to pull the engine, becuase 9 times out of 10 your going to have crank damage
lougreen03 Aug 23, 2012 11:53 PM
A motor with a bent rod would need a complete rebuild.
Franks 03SS Aug 24, 2012 07:51 AM
Or you could get a donor motor and drop it in, but rebuild Would be better... :thumbsup:
ChibiBlackSheep Aug 24, 2012 07:58 AM
If someone had a bent rod, I would just recommend getting a used block.
So if you are going to buy an engine with a bent rod, I wouldn't even bother.
STUMPMI Aug 24, 2012 01:46 PM
Just replaceing that 1 rod isnt going to work...It means that theres some other significant damage done to it....U need to rebuild the complete motor...Includeing line honeing the mains. etc... no other way to do it...other than a complete and different engine change...
04chevyboy Aug 24, 2012 10:13 PM
hmm,im not even gonna bother with the gtp's then,ill only need it for 1 winter lol
