Random M90 Question
Old Sep 12, 2011 | 09:33 AM
oneslowmonte's Avatar
Default Random M90 Question
I was given the snout and base of an M90 but I need the plate that connects the two and do not know what it's called. Any ideas or tips on finding one? Thanks.
Old Sep 12, 2011 | 10:04 AM
nitehawkjcb's Avatar
The snout bolts to the case...
Old Sep 12, 2011 | 02:29 PM
Are you sure?
Old Sep 12, 2011 | 03:50 PM
I'm 95% sure, there is another piece that looks like it COULD come off, but I've had my blower apart before and that thing won't come off.
Old Sep 12, 2011 | 07:36 PM
Middle piece is just be the rotor pack, gears on one side, rotors on the other:
Might be kind of a pain finding it separate unless you find someone gutting their case for a turbo setup.
Old Sep 12, 2011 | 09:00 PM
Hmmmm, I think I need to go up in the attic soon and check out my supercharger base, it has that spot for the coupler but it doesn't look like it has the plate, maybe I'm going crazy..
Old Sep 13, 2011 | 07:18 AM
z34phoenix's Avatar
if it is an incomplete M90, its not worth piecing together just get another one.
Old Sep 13, 2011 | 08:51 PM
On second glance I think it has the plate, I guess all I need is a coupler? and the bolts. I have the snout it's just not pictured EDIT: Sorry for the size!
Old Sep 18, 2011 | 08:25 PM
Yes, you are missing the coupler- it goes on those 3 prongs sticking out of the right gear. Real cheap at zzp. Plus you need SC oil too, since it is obviously missing that.
Old Sep 19, 2011 | 05:38 AM
If I do not know the condition of the supercharger should I have it rebuilt? Or just stick it on and see if anything goes wrong?
