A question of Timing.
I have a question that has been running around my head for a while. is there a way a 3.8 can run without its host PCM?
Let me explain. Is there a way to fire the plugs with a stand alone system? Also, since and engine is basically an air pump, i dont see a reason why it couldn't work with carb. Maybe a Holley. Is ther a problem with my logic? I know that it would mean that a new intake wold have to be made. Or better yet. Can the PCM from say a GTP be stripped down to just work the engine alone? Just use what needed ( sensors and stuff ). I dont want it to control the Trans. I have separate plans for that. I have my reasons for asking this and i have till April to find out answers. |
Been doing some reading and found something called a MEGASQUIRT 2. Does anyone have any knowledge of this system?
obvious jokes are obvious......
Not THAT kind of squirt.
sheesh. LOL |
I just looked at ZZP and they seem to have just what i need. A PCM with everything removed except what is absolutely needed. VERY KEWL!!
I think talks with them might get your answers then.
Once i have a donor car with an L67, i'll start calling them to see about getting it flashed.
ANd no, its not going into my Monte. |
I figured you wouldn't do that with your Monte :P
Regal? |
Nope.
Lets just say that its going to be ....... KEWL!! |
is there a way a 3.8 can run without its host PCM? Also, since and engine is basically an air pump, i dont see a reason why it couldn't work with carb. Maybe a Holley. Is ther a problem with my logic? I know that it would mean that a new intake wold have to be made. If you really want a carb'd 3.8; why not get one of the old 80's ones? Can the PCM from say a GTP be stripped down to just work the engine alone? Just use what needed ( sensors and stuff ). I dont want it to control the Trans. Been doing some reading and found something called a MEGASQUIRT 2. Does anyone have any knowledge of this system? Once i have a donor car with an L67 |
| All times are GMT -5. The time now is 08:37 AM. |
