pcv valve replacement?
Old May 28, 2008 | 07:08 PM
jay26's Avatar
Default pcv valve replacement?
just checked it out and still good meaning hearing a rattle when shaking acording to helmes.i got almost 80,000 and they say check and replace every 30,000.should i replace?or is everything fine as long as it rattles.
Old May 28, 2008 | 07:14 PM
DEI Monte SS 04's Avatar
Default RE: pcv valve replacement?
If you want to do it that way (the cheap way) Blow in one side air shouldgo right threw.,blow in the other side no air should pass threw
Old May 28, 2008 | 08:04 PM
RickCoMatic's Avatar
A new one is a whole 4-Bucks. Why don't you treat your baby to a new one. It's cheap enough to do two!
05montec
Jan 12, 2013 06:18 PM
wtxbear
Aug 20, 2012 08:25 AM
70monte1
Mar 30, 2012 10:31 AM
buffbison82
Jan 9, 2010 04:27 PM
Redestwing
Aug 4, 2008 05:23 AM
