PCS and overdrive
Right now I'm getting the dreaded p1811 code. I know the PCS needs to be replaced but my question is this. Since the PCS has gone out, I'm assuming I have no more Overdrive? At 45 mph, I can feel the car shift into overdrive but the RPMs remain the same. Or could this be totally unrelated? A bad TCC or stripped 4th gear?
Check this link to see if they can help you out
Check this link to see if they can help you out.
https://www.justanswer.com/chevy/3ez...nte-carlo.html |
