Overheating and found this thing unplugged
Any idea on we’re this plugs into my car is overheating and while trying to find the problem found this lil thing hanging by the alternator. Any ideas on what could be causing the overheating just replaced radiator and fuses not to long ago. Radiator fans not turning on https://cimg3.ibsrv.net/gimg/monteca...1838fdbb7.jpeg |
That's an extra harness plug,,, it goes nowhere and has nothing to do with your issue. whitch fuses? for the cooling fans? if they have blown in the past then you have a problem in that circuit. no fans running =overheating. you could check to see that both fans spin freely and aren't hitting anything to prevent them from spinning.
Originally Posted by sharpeezss
(Post 710956)
Use a voltmeter to see if there's a short on the fans or the harnesses that plug into the fans.
Also re-check the fuses, are they popping again? Are the fans kicking on at all? |
