Oil in Radiator
Old May 10, 2007 | 01:25 PM
do3r17's Avatar
Default Oil in Radiator
Can anyone help me out here. I have a 96 monte carlo LS, and oil is getting in the radiator. I'm thinking it has somethign to do with the intake.
Old May 10, 2007 | 01:31 PM
Mrrench's Avatar
Default RE: Oil in Radiator
I would almost say you have a head gasket problem...
Old May 10, 2007 | 01:34 PM
wiz kidd's Avatar
head gasket
9957pt is the felpro part # ...your gonna need 2 (this is for the 3.1l)
if you have any oil in your rad, or antifreeze in your oil(this is the way it usually happens) then its usually the head gasket
Old May 10, 2007 | 01:39 PM
scc24540's Avatar
haha yup my 3.1 did that to me, the problem is the severe angle of the lower intake gasket has a bad habit of splitting. but yeah DO NOT START the car until you fix this problem of you will be suffering down the road. tis why i built a new engine, so either head or lower intake gasket is 100% the problem
Old May 10, 2007 | 01:44 PM
wiz kidd's Avatar
get the ms98004t gasket kit for the intake manifold too while your at it you may as well do it right...
Old May 10, 2007 | 01:50 PM
scc24540's Avatar
thats true josh, u gotta take it off to replace the head gasket and u might as well go with the best replacement you can find or else you'll be doing this again later on down the road unfortunatly
Old May 10, 2007 | 02:56 PM
do3r17's Avatar
wow, thanks for all the replies guys.
Old May 10, 2007 | 03:39 PM
scc24540's Avatar
anytime son, thats what we're here for
Old May 10, 2007 | 03:43 PM
GrandPaDave's Avatar
I was wondering if anyone has mentioned, "head gasket?"
(just another GPD ***** post)[sm=yeahsmile.gif]
Old May 10, 2007 | 03:53 PM
scc24540's Avatar
ORIGINAL: SolaraSlayer
GPD whats a head gasket? is that the thing that keeps your hair dry?
