oil pressure sender/sensor
Alright getting a code for this, intermittently my oil pressure gauge doesn't work. Prob need to replace this to pass inspection too. Where is this located?
going by your pic i am assuming its a 00-05. not sure what engine you have but if its a 3800 its on the passenger side by/on the oil filter neck.
(Post 559018)
You are correct it's a 2000 with a 3.8. Thank you very much! |
I just changed mine, but i have the 5.3. Mine was on top of engine, a lil to the right by the throttle body, you need a special socket for it I believe, even for the 3800
