Oil Pan Leak
Old Jun 8, 2012 | 11:57 AM
butch049's Avatar
Default Oil Pan Leak
Might have minor oil pan leak heard this is comman in 3800 anybody had this problem? Thanks Butch Hard fix?
Old Jun 8, 2012 | 12:50 PM
IffyG's Avatar
Pretty much every 3800 will develop an oil pan gasket leak at some point. It's a major PITA to replace since you have to drop the engine cradle to get at some of the bolts. I lived with mine leaking until I had the transmission rebuilt and the shop could get at it without any additional labor.
Old Jun 8, 2012 | 02:20 PM
x2, mine has a small leak. I just keep an eye on my oil levels and make sure to clean the pan every oil change.
Either this gets worse and warrants the fix, or I'm waiting until I have to drop the cradle for something else so it can get done.
Old Jun 8, 2012 | 08:01 PM
butch049's Avatar
Thanks guys that is what my buddy said today when changing oil .up on lift. Dropping cradle big job $. Thanks Butch
Old Jun 8, 2012 | 10:12 PM
Maybe you could tighten the bolts a bit and get the leak to stop for a bit. I have done this on other vehicles before. Not too tight tho they will snap.
texan767
Feb 18, 2015 04:38 PM
ezmoneybaggz
Aug 18, 2013 10:44 AM
crete
Nov 6, 2011 07:05 PM
koreancore
Jan 14, 2009 04:59 PM
black2001montess
Aug 27, 2007 04:45 PM
