-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   No A/C (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/no-c-35806/)
James O'Conor Apr 18, 2012 08:33 PM
No A/C
I have a 2001 SS, the A/C compressor was just replaced. Now there is no power to the compressor. It will run if power is put directly to it. I am brand new to the Monte Carlo... it isn't even registered yet, I was wondering if anyone had any suggestions or had a similar problem. Thank you in advance for any help.
lougreen03 Apr 18, 2012 09:58 PM
I would check all the fuses and relays. There are fuse boxes on both sides of the dash and under the hood. Also check the connections. If there was power before It has to be a fuse or connection.
ChibiBlackSheep Apr 19, 2012 08:45 AM
Did the shop that replaced it put enough freon in?
James O'Conor Apr 19, 2012 02:22 PM
I don't know, they still have it, but they say that when they put power directly to it the compressor kicks on.
ChibiBlackSheep Apr 19, 2012 06:59 PM
If these systems are low on freon the compressor won't kick on (these systems have oil to lubricate the parts) it's to protect.
I would ask them if they put enough in. These cars do take a good amount.
The_Maniac Apr 19, 2012 09:37 PM
Chibi is right about the is freon. If the freon is too low, as a safety, the compressor will NOT turn on. I've seen people re-charge the A/C on a car and once enough freon enters the system, the compressor kicks on.
ChibiBlackSheep Apr 20, 2012 08:17 AM
Or maybe they filled it up, but you have a leak elsewhere.
James O'Conor Apr 23, 2012 01:37 PM
Ok, for those interested, my Monte is at the dealership now, the wires from the BCM to the PCM is being replaced. They say that that should be the problem. I will know in a few hours. Another $375!
ChibiBlackSheep Apr 23, 2012 03:21 PM
I would think you would have much more problems if those wires were bad...
