RE: newbie motor swap question on a 97 Monty
I agree on the L67. I sold my '01 SS to buy the '04 Intimidator SS BECAUSE of the L67 engine.
DON"T forget to upgrade your axles. Something was said about hybrid axles. Not sure about that, but I DO know that the L67 not only has the 4T65E-HD transmission, but also the HD axles. Get them also, but you might still have to modify them? Also, you will have to replace the fuel pump with the heavier unit, as well as the fuel lines with the larger lines for the L67 to get enough fuel for the larger, more HP motor. |
[/quote] I agree 110%, he was talking about swapping it in a near stock form to ease future repairs and such- and in that aspect an L67 would be much better. Stock for stock, an L67 would make more power than a 3400 or 3500 swap. Not to mention you could put the car into the low 14s/high 13s for under $1000 in mods- something that would be completely unheard of with a 3400. [/quote] well yet again going back to what i am saying you are comparing aples to bannas the l67 is s/c from factory and i get the hole bang for the buck thing and you are right about the 1000$ in mods be cause of the factory s/c put a stock 3400 with a stock 3800 n/a and put 1000$ of mods and there you have a diffrent story !! that's what i am trying to say |
ORIGINAL: RocknSS04 Not sure about that, but I DO know that the L67 not only has the 4T65E-HD transmission, but also the HD axles. Get them also, but you might still have to modify them? Also, you will have to replace the fuel pump with the heavier unit, as well as the fuel lines with the larger lines for the L67 to get enough fuel for the larger, more HP motor. As far as the fuel lines go, I can't find the part #s for them between a 3100 and 3800 5th gen monte, so I don't know if they're different. I know we had one guy running stock lines (from what I remember) on a 400+ whp turbo swap that ran 11s. So I don't really think bigger fuel lines are that big of a deal unless you're going really hardcore. Obviously a good FP gauge and some scanning will tell you for sure if you do get that deep into it. put a stock 3400 with a stock 3800 n/a and put 1000$ of mods and there you have a diffrent story !! Same goes with a complete 3400 swap. I realize some people love the 60* engines- but if you're spending all that time to swap engines, and he wants the most power he can in near stock trim, it just seems like a no brainer to me. |
First off thanks for all the replys, I'm picking up the car in 2 weeks in Denver, and brining it back to my house in Grand Junction, CO. In the mean time, i plan on gathering a parts list and ordering up all the parts so my brother can come down for a long weekend and we can knock out 90% of the swap over the weekend he's here. So onto the parts list...please feel free to correct or add to it:
-98-04GPGTX L67 motor - 98-04GPGTX 4t65hd Tranny - 98-04GPGTX PCM - 98-04GPGTX pass side axle shaft (use inner for the tranny, and split the stock monty shaft for the outters) - 98-04GPGTX fuel pump - 98-04GPGTX tranny lines - 98-04GPGTX power steering lines -98/99 Monty 3.8L driver side shaft. - 98/99 Monty 3.8L wiring harness - 1 case of new castle brown ale The other hoses ect..i can buy from NAPA i assume? So what else am i missing |
-98-04GPGTX L67 motor Also, 98 still had much higher than normal head cracking (like the 97s). Depending on built date, it could be the old or new head design. I would say more ideally would be 99-03. - 98-04GPGTX fuel pump - 98-04GPGTX tranny lines - 98-04GPGTX power steering lines For the low pressure line you can just use fuel injection rubber hose- pressure is way lower on the return. The other hoses ect..i can buy from NAPA i assume? |
great, thanks for the input....so is there anything i can do to bump up the power just a bit more while i got the motor out that won't cost too much or stray to far from the stock set up? Also...any suggestions on susp, we're thinking we might replace that as well since it's got 100K on it already.
ORIGINAL: wally so is there anything i can do to bump up the power just a bit more while i got the motor out that won't cost too much or stray to far from the stock set up? -zzp power log ~$120, just replaces the front exhaust manifold, supposed to be good for ~10 whp -1.9:1 modified stock rockers ~$275, pop the valve covers off, and toss on new rockers, pretty easy job with the engine out- I'd figure it would be an easy ~20 whp -bigger TB- Northstar w/ adaptor, usually ~$300/kit, simple bolt on (really needs a ported blower to take full advantage of it), even still I would think you could pull maybe 5 whp out of it- more with a ported blower- its just 3 bolts to get the old one off -ported supercharger $175-$350 depending how far you want to go, maybe 12 bolts to pop the blower and fuel rail off- fresh gasket, and pop the new one on- I imagine you could get 10 whp off this, especially with a bigger throttle body If you do enough of the above mods, you could slap a 3.4" or 3.5" supercharger pulley on there (press on pulley runs about $50, full modular pulleys run about $100)- but that would be an easy 20+whp assuming you had some of the other supporting mods above. I just don't know how much you want to spend or how deep you want to go- just about any of those will make a nice power increase by itself. If I had to do only one thing on that list though, it would probably be rockers- it gives a lot more oomph to the engine. Also...any suggestions on susp, we're thinking we might replace that as well since it's got 100K on it already. BMR sells new lateral and trailing arms for the rear w/ fresh bushings, but those are ~$500. The only other thing to really refresh would be outer tie rods and ball joints- both of which you could just get good stock replacements. |
Maybe take a trip to the junkyard and look for a 97-99 z34 to steal suspension components off of. I know the brakes are bigger on the z34s and they also have the largest swaybars. I think there is some difference between the ls and the z34 struts. The z34s are stiffer. I have driven a 98 ls and the difference in handling is night and day between the ls and my z34.
You could do the rear disk swap off a z34 too.
I'd be kinda afraid to buy used springs/struts off a z34 unless it had pretty low mileage. The rear sway bars are identical between your 97 ls and a 98/99 z34. The 95-97 Z34 sway is a different part #, not sure if its a different diameter or not. For sure the front sway is bigger on a z34, but its only a touch bigger (I think I went with a 98 Z34 front/rear sways- thats when I found out about the same rear sway). |
ORIGINAL: bumpin96monte -zzp power log ~$120, just replaces the front exhaust manifold, supposed to be good for ~10 whp -1.9:1 modified stock rockers ~$275, pop the valve covers off, and toss on new rockers, pretty easy job with the engine out- I'd figure it would be an easy ~20 whp If you do enough of the above mods, you could slap a 3.4" or 3.5" supercharger pulley on there (press on pulley runs about $50, full modular pulleys run about $100)- but that would be an easy 20+whp assuming you had some of the other supporting mods above. |
