need to no something
if you have a 4.3 chevy V6 you can change it out for a 305 and everthing is the same trans bell housing and motor mounts
if you have a 3.8 buick V6 then the motor mounts will not fit so that will need to be change and if you have the o/d trans 200r4 (they have dual bolt patern) that will bolt up but if you have any other trans that will have to be changed too !
iMSeRiOuS
Dec 25, 2012 03:23 PM
lucian*91
May 26, 2010 10:00 PM
