need help with cooling and heating system
my 2002 monte carlo antifreeze coolant keeps leaking from top and below the radiator from both hoses i tithing them but the pressure still makes them leak , does that mean the radiator is bad or water pump, i recently replace the thermostat three months ago , and the fans do turn on and off like normal " the car would overheat a little pass the middle but it usually goes back down again:confused::confused:...
Hi `Zyon,
Sorry 2 read that U are having problems.. How many miles on your Monte ? Have you ever flushed your system ? If so, when ? How long or miles ago ? Are your clamps on your hoses tight ? Are they the original hoses ? Please post as much infor about your problems so when our expert tech member's reads your thread it will help them advise, or suggest a solution...Good Luck 4-Sure |
Originally Posted by KidSpace
(Post 307444)
Hi `Zyon,
:rolleyes:...Thanks for the update & additional information....
I hope that one of our expert member's can assist or give you some idea what could be wrong.... Good Luck 4-Sure.... |
(Post 307508)
No heat untill i drive
Originally Posted by zyon555
(Post 307442)
Originally Posted by Monte60
(Post 719932)
My car doesn't get heat till i drive i only have 59,160 original miles i take care of my car im low on coolant? Why do i need to get a pressure test on the system? Please help me i love this car.
(Post 719937)
Please start a new thread as this one is 8 years old. It's rather difficult to help without more information.
If you have a issue it's best to start a new thread, but I'll try to help. If your car is low on coolant you show really try and find the leak. It's a sealed system so the cooling just doesn't disappear and a pressure tester is the best tool for the job. You add fill the system , add air pressure with the tester and look for the leak. As for why you don't have heat , I'll guess your referring to the heater/defroster . If the system is low this is usually one of the results and another possibility is the heater core is plugged because of the age and that would usually require a back flush to fix the problem.
| All times are GMT -5. The time now is 01:24 AM. |
