ls4 engine swap on 2004 monte
Unfortunately there aren't really any choices when it comes to plug and play transmissions. The 4t65 is it.
Given the LS4's propensity to eat transmissions, I'd at least get a basic build from a place like Triple Edge - even if you're leaving the engine stock. If you're going to mod it, you'll want to opt for a higher end build. A lot cheaper to build it strong up front than to half build it, blow it, and have to do a brand new build.
Any other transmissions will require custom work. 4t80s have been done as have one or two manual transmissions - but all involve some level of modification to work.
What kind of power are you shooting for?
But having personally owned a stock LS4 with its matching "HD" transmission and still having had it fail with gentle use, I'd never consider owning one without an aftermarket build.
Opinion Needed: Engine swap advice
Malachi
Jun 10, 2020 09:19 AM
5th Gen ('95-'99): Engine compartment sizes
Crestview79
Aug 1, 2012 10:46 AM
scottwern184
34
Jun 4, 2010 06:20 PM
