Lost electrical connector.
Hey guys, Sorry I haven't been around much lately. I recently lost a rod in my 2002 monte SS. I replaced the motor with another low mileage series II 3800 this weekend, but I've got one connector that has me stumped. Coming out of the wire loom at the same location as the two alternator connectors and O2 sensor plug I have a 2 pin (2 wire) connector with nothing to plug it into. The boot around it appears to be dirty like it wasn't plugged into anything before, but I'm curious what this is for. It's only about 4" long where it comes out of the main loom by the alternator.
Does anyone know what this connector is for? Or can someone please check theirs and let me know what they discover? Thanks so much for any help on this.
It is probably the connector for the AIR system. Some cars had it and some didn't.
Best way to see if you have it or not is to check the underhood fuse box. You will see a spot on the front cover for "AIR system" but it will have dotted lines around it and there will be no relay in the fuse box.
02LS
FWD Tech Guides '95-'07
Oct 19, 2018 02:40 PM
