lost
help me please, every 3 to 4 turns to crank the car up it misses the fly wheel ive took off the starter and had it check it came back as good, when it misses i can get under the car and kind of move the fly wheel sometimes this will work but its a pain i dnt knw what to do can some one please help me ...........:confused::confused::confused::confused ::confused::confused::confused::confused::confused ::confused::confused:
Is the fly wheel missing teeth?
Sounds like eaither the silanoid is on it's way out or sonera one tried to start the car while it was running and it sheared some of the teeth a bit so is not making good contact, which would mean replacing the flywheel
the fly wheel has all its teeth ,and i had my starter rebuilt took stater again this week end and had it check and it was working . i switch from a reg starter to hp starter should i go back to a reg?
