L67 Top swap or Turbo, which one??
Don't forget the $4,000 for the new transmission,
$4K is really, really high for a new transmission- Triple Edge's drop in units start at $1500.
http://www.tripleedgeperformance.com/Transmission.html
and the HD axles. The axles are the weak link in the whole drivetrain. Just ask ZZPerformance.
Turbo setups are a different story- the massive power/torque created by a decent turbo setup is pretty much guaranteed to destroy your transmission.
Speaking ONLY about BIG power cars, I beg to differ on the differentials being the weak link. YES, they ARE a weak link, but if beefed up properly, the axles become the weak link. At least that's what Steve at Certified Transmissions (the guy that built ZZP's drag car's transmission) told me. The tranny and dif' can hold 900+ HP, and at that point, the axle assemblies become the weak link.
And yes, $4,000 IS a lot of $$$ for a transmission, but $1,500 will get you something not much more than stock. A good transmission will cost you $3,000-5,000. Don't forget a good torque convertor, maybe a Mezier flex-plate, etc, etc. $3,000 comes FAST! An advantage is you have 3.29 gears, but a dis-advantage is you don't have a core for the HD tranny. I've gone thru the numbers game with them and ended up with a 2,500 stall convertor, and that's it. (3rd torque convertor for me, along with 3rd flex plate).
Speaking of flex plates, make sure you get a Bonneville flex plate, not a Chevy or GP. They are stronger, I'm told (by ZZP)
Rian, how much you got into yours? How much power you putting down?
Is this going to be ONLY a street driver, or are you going to run the 1/4 occationally? A top swap, you're probably OK with a beefy 4T65E-HD, but anything more and ?????. I shredded a tranny in my '01. It wasn't pretty.
If you're at the point where you're worried about snapping an axle on a daily driver, then you're going to have a whole lot more to worry about with replacing that transmission chain every few months.
Sure they can hold 900hp or so, but for what? A couple track passes?
Most turbo guys running pretty big setups (400whp+ on street cars) don't seem to have axle issues, but definitely go through chains like there's no tomorrow.
-Riggs.
-Riggs.
http://intense-racing.com/Merchant2/...ategory_Code=T
you need to get one of this from intense-racing if you planning to run some sticky tires
Turbos will give you more power, but for a daily driver, I'll take a positive diplacement blower. Turbos put up great dyno numbers, and have great top end. But I just can't gt over the lag of a turbo setup. As for a custom Whipple...thats probably a pipe dream unless you are really good at fabricatin things.
