ID Tag Unreadable?
So I got to the transmission ID Tag on my '01 Monte and low and behold its had an exhaust leak so the tag is unreadable. I mean its burnt up black so bad that I can only see the stamped codes at the top of it. I tried cleaning it with some Dawn dish liquid soap and a toothbrush and still nothing.
Oh and this car was wrecked at one time and had the trunk replaced so I can't rely on the service parts identification tag either. As the one in the trunk is out of an '02 Monte which is not mine of course. :( So am I screwed? Where can I find what transmission went in this thing? Can GM tell me from the VIN? Can they look up from the VIN the service parts identification tag maybe? Thanks guys. |
What number do you need?
You should have a 4t65e transmission in that car. |
(Post 554345)
You should have a 4t65e transmission in that car. I'm safe if I go with a '01 Monte Carlo transmission but I wanted to have some options of going with an Impala '00 through '02 or even a '00 or '02 Monte Carlo. If I can't get that transmission ID tag read then I'm limited to staying with an '01 Monte Carlo transmission. I didn't really want to limit myself to only that model year. |
There's no gear ratio changes in the 00-02 so you are fine there. There's also no difference in the Impala as long as it has the same engine.
(Post 554468)
