-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   HOW MUCH HORSE POWER IS SAFE FOR ENGINE (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/how-much-horse-power-safe-engine-10698/)
dan Sep 23, 2008 04:28 PM
i have a 2005 monte ss sc and was wondering how much horse power i can add without hurting the engine. Also what would be the safe'st upgrades i can do. i would like to get at least 300hp. i found a web site that has a lot of after market things (www.partsforyourcar.com) Also do you no were i can get a o2 simulator for my car, cant find one for 05. Thanksfor thehelp
tackett24 Sep 23, 2008 06:53 PM
RE: HOW MUCH HORSE POWER IS SAFE FOR ENGINE
Well first thing forget that site. Go to ZZPERFORMANCE.COM you will find everything you need there at a lot better prices.
bumpin96monte Sep 24, 2008 12:22 AM
If you have to ask that question, then its likely that you will never make enough power to 'hurt' the engine. They can handle way more than 99.9% of people can throw at them.
-cold air intake or fenderwell intake
-3" downpipe
-drilled 180* thermostat
-modded stock 1.9:1 rockers
-powerlog
-3.4" supercharger pulley
-aftermarket pcm or custom tune from local
Thats the easiest/cheapest way to make 240whp which is ~300bhp. Its been done for $500 buying used stuff- I'd probably budget $750 to be safe. You can make way more power if you want- just depends on your budget.
x2 on zzperformance also check out www.wbodystore.com and lastly www.intense-racing.com (go in that order if you can't find something).
RocknSS04 Sep 30, 2008 06:43 PM
Add an N* throttle body to the list, or at least a ZZP ported TB.
AND COLDER PLUGS! I have NGK iridiums, for longevity, but for PEAK performance, buy the Autolite 103's
bumpin96monte Oct 1, 2008 04:57 PM
Good call on plugs, I totally forgot about those. If you didn't plan on modding anymore than the above, stick with Autolite 104s though, the 103s are a pinch cold for them from my experience. If you plan to keep modding, the 103s are the better choice. Just keep in mind that they are copper plugs, and will need to be changed much more frequently.
As far as the TB, a N* is a great mod, but it shouldn't be necessary to run the 3.4" knock free. I would say it would be the next thing I would do after that list though, if you wanted to keep going- followed by a ported blower.
