high flow injectors
hello I am in the process of s/cing my L36 engine up to 300 hps and I am wondering why should I upgrade my injectors if they're good up to 300 whp?
this is off of the zzp website where they state that....
thanks
thanks
what am I risking in not replacing them? its an 02 monte ss as well. I was going to get them until i saw that note on zzp. still need fuel rail throttle body and injectors then I should be good to go.
well just the intake to date..... before my sc goes in... I'll be deleting ubend, larger downpipe, high flow cat, and better mufflers, you know the cheap stuff at the back before the expensive stuff at the front. I have an m90 supercharger which I'll be replacing the couplings, and I have L67 heads too. need fuel rail, injectors and throttle body off of the L67's. and then I do my ecm modifications and my compression ratio too, bleh. oh well its good times.
also put on custom headlight covers which are same color as the car and LED tail lights plus doing some interior stuff to it soon and new hood as well plus SLP front grille I've saw..... its al a project right.
02 monte ss, it has the limited edition ground effects which I'm going to paint red to spice it up. whats the system you have in it? I was going to change the amp and put subs in it..... dont know if I can though due to the computer crap in the stock cd player unit
