-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Help with back plugs (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/help-back-plugs-15458/)
chevyrider08 Aug 19, 2009 07:24 PM
what is the best way to access the back 3 spark plugs on a 3400 monte carlo?...what needs to be removed etc...?
ChibiBlackSheep Aug 20, 2009 08:44 AM
Undo the dog bones, and rock the engine forward.
Also some people like to use a ratchet strap and tie it to something (like a tree) and the other end to the engine mount and pull it forward and hold it that way.
MAMONTE Aug 20, 2009 12:20 PM
So just because i'm curious for the next time I replace spark plugs, when you undo the two dog bone engine mounts, does the engine really just rock forward? There is nothing else that needs to be loosened under the car? Just undoing those two mounts allows you to move the engine forward without doing any harm to lower mounts, or the transmission?
ChibiBlackSheep Aug 20, 2009 12:35 PM
It's not like the thing is moving a substantial amount, it will move the length of the dog-bones... what is that like 6"?
And it's not SUPER easy to rock it.
MAMONTE Aug 20, 2009 12:51 PM
Well I might just have to try that when I replace my plugs again at 100K.....
Pure2sin Aug 20, 2009 01:43 PM
People don't like this idea but look up "Engine tilter" in the search for the forums. I bought one and it worked great for me basically same thing as the strap but you don't have to worry about a strap coming loose or the thing the strap is connected to breaking off. Was worth is for the piece of mind.
bumpin96monte Aug 20, 2009 04:12 PM
Yes- the only thing keeping it from really moving at that point are the lower mounts which are rubber. The higher the mileage and the more worn the lowers are, the easier it will be to rock. Everything else will just flex with it (hoses, axles, etc).
monte carlo 3831 Aug 20, 2009 04:20 PM
http://www.amazon.com/Thexton-419X-E...363&sr%20=8-14
engine tilt from a previous post by Pure2sin
MAMONTE Aug 20, 2009 06:27 PM
Good to know, thanks...is this the same way the dealers do it?
03Monte Aug 20, 2009 07:03 PM
no, the dealership will make you buy the puller, the labor to to open the box, smoke a cigarette, use the bathroom, change the plugs, and then charge you "Shop fee's" which boils down to toilet paper and shop rags...
and no, i have no love for dealerships...lol
