Help with 3800 xpz tuning.
Hey guys. What a nightmare. My monte has been gone over a year with building and repairing parts. Please don't ask lol. I need help with tuning. The basic power adders I have are as follows: ported gen 3 blower with 2.8 pulley. Northstar tb kit. 2 short stack inter coolers with 5 gallon reservoir in trunk. -8 fuel lines and -6 return line with a walbro 455 pump. I also have custom aeroforce fuel rails. I'm running e 85 and am on 60 lb injectors. I have pacesetter headers with 3 inch downpipe and an exhaust cutout on the downpipe. This leads to a 2.5 inch exhaust. My tuner says the 60 pound injectors are too small as the car leans out at 5200 Rpms. He ordered me 100 pound injectors so we can hit 6500 Rpms as I'm sure a this car can hit. It's on 24* timing and only hit 275 wheel and 300 Tq. He says the exhaust is too small and that I need 3.5 inch exhaust and my xpz cam is too big for the ported gen 3. When I did the original ssm90 kit from zzp with a single belt setup and 3.4 pulley, no heads or cam,I ran 276 wheel on 93 gas. How is this possible???? Can some one please help so I can tell my tuner what to do??? Thanks in advance
Originally Posted by 03vaderSS
(Post 698129)
You should be able to do over 6500 on an xpz cam once you get the fuel you need. Only running it out to 5200, you're definitely taking a hit on power. It's on 24* timing and only hit 275 wheel and 300 Tq. He says the exhaust is too small and that I need 3.5 inch exhaust and my xpz cam is too big for the ported gen 3. Can some one please help so I can tell my tuner what to do??? Thanks in advance 1. Find a different tooner. This one clearly has no idea what he's talking about. A tuner can make or break a setup, especially one as modded as yours, he may be holding you back. 2. Get bigger injectors, 80s, 100s, 110s, whatever and make a pull to at least 6500. Then you can compare apples to apples with before and with everyone else out there. 3. At that point you'll be good on fuel, you're already beyond good on spark timing. If it still doesn't make power, id start verifying mechanicals- checking for valve float on the dyno chart / scan logs, check compression and compression variability, ensure you're getting wide open throttle, etc. If you get to that point and still aren't making power, id sell it all and buy a turbo (or a different car platform), lol. |
The gen 3 was ported only the outlet and lim by zzp and I took it to a shop to port the inlet to match the northstar tb. I had my heads re polished and valves redone and runners opened up a bit. It doesn't make sense
Also I'm not sure if this will be a factor but I had zzp flash my PCM becuAse my tuner was unable to access the 2 bar map. So I did that months ago and my tuner said that they deleted all the info he had in the PCM from 2 years ago and complained that he would have to take more time and more money to put everything back in and that it is easier to run the 1 bar map and the old PCM that already has the old
Info from the 93 tune which ran 330 wheel horse and 320 tq. I asked him if the bossy would be affected by doing this and he said no. I was running 15 psi on the 93 tune on a 3.1 pulley with half the mods 2 years ago and now I'm only at 13 pounds of boost on the 2.8 and e85. Does the 2 bar map need to be used? I will find out the a/f ratio and post it today. What do you think bumpin96?? |
(Post 698138)
You mention having the heads redone, where were they ported? If theu werent ported by a 3800 shop, did they provide flow numbers showing an increase? Not that I think that's the key to the problem, just trying to understand. |
My tuner brought the heads to his shop he always uses. I asked for the flow numbers
But he didn't get them from the porter. He said the runners were only opened slightly more than they were. I know it's unclear but at this point i don't know what to believe. What about the 2 bar map? Could that have any affect? |
(Post 698139)
Info from the 93 tune which ran 330 wheel horse and 320 tq. I'll also ask it again because it's very important - are all these figures from the same dyno? If theyre not, then a comparison is worthless. I was running 15 psi on the 93 tune on a 3.1 pulley with half the mods 2 years ago and now I'm only at 13 pounds of boost on the 2.8 and e85. The only thing you should be looking at boost for is it see if it falls off up top from belt slip. Does the 2 bar map need to be used? I will find out the a/f ratio and post it today. I guess we could look at the rest of the pull, but at this point it doesn't matter anymore. You're going to get new injectors and will need to be retuned for them, so that's what is important to see. I'll still reiterate, it's time to ditch this tuner. Too many red flags IMO. May not be your only problem here, but it is clear that he doesn't know what he's doing with 3800s. |
(Post 698143)
My tuner brought the heads to his shop he always uses. I asked for the flow numbers. But he didn't get them from the porter. He said the runners were only opened slightly more than they were.
I'd also be pretty irritated that they didn't flow them to show improvement, especially if you asked for it. They could've made the heads worse and you'd never know. Again, unless the shop is really bad, I don't think this is the key to your problem, I just would've went the route of a major 3800 vendor doing them since you really seem to be going for a big m90 build. What about the 2 bar map? Could that have any affect? |
I wanted to run the 2 bar with the flashed PCM but he said it would be a more expensive tune and take longer to tune. I emailed Zoomer and he said either the cam is installed wrong or the timing is way off and I should be making 100 hp more
The only other power mods I have added since last time was an exhaust cutout, removed the high flow cat, e85, -8 fuel lines -6 return lines, 2.8 pulley , ported sc inlet, northstar tb kit, a second short stack inter cooler and a 5 gal coolant res. I forgot to
Mention last time I was using an xp hot cam. I just hot off the phone with my tuner and I mentioned what you were saying and Zoomer from zzp and he sticks by his head shop who has ported heads for 3800s a lot. Also he claimed the cam is installed correctly which I believe it is as well and the timing was not done wrong because I already had the double roller installed with my xp hot cam. He said the af ratio was 13 at 5200 Rpms wot and he was letting out. He said it should Have been 11 and we should be hitting 6500 Rpms with the 100'pound injectors. He is saying it will gain power from the bigger injectors but I can't see 100 like Zoomer said missing out on with my build. It's aggravating. I've spent too much with add ons and e85 to make less power. It doesn't make sense even Zoomer said it's hard to make less power even with a lot of error and with my mods especially. I don't know what to do. If the cam was installed wrong, wouldn't the car be undrivable? |
