-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   heater issues (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/heater-issues-32182/)
gelfuel Nov 17, 2011 03:29 AM
heater issues
The air is not as warm as it should be but the engine temp is 195? Replaced thermostat and bled air out of system. Noticed that the a/c cooling line is cold and compressor is running?
Shandley Nov 17, 2011 07:03 PM
Perhaps the A/C relay is stuck in the closed position?
Usually, I put my A/C on with the heat to get rid of the fog but turn it off plenty before the engine gets warm enough.
gelfuel Nov 18, 2011 03:45 AM
Thanks, I'll check it out.
