-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   gas smell in oil?? oh boy (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/gas-smell-oil-oh-boy-15688/)
PINKFLOYD_ Sep 1, 2009 01:18 AM
I bought the 2004 mc ss in april, with 26k miles on it. I change the oil every 2k miles (i love her dearly). I've only had her up to 95 max only a few times (2) while warmed up on the highway while starting at 65mph ish. I changed the oil today and had a bon fire. My friend said "well fresh oil wont catch as easy, use old oil"...A few hours later I tried the fresh oil..just as curiosity,,,,.well, it surprised both of us. Considering my other friend would burn oil for bon fires and would take quite a while for it to catch. Along with every oil change, I add lucas Oil Stabilizer...Is this what Im smelling? The car currently has 32k on it.
thanks for the help.
TheMonteMan Sep 1, 2009 01:58 PM
did you try to ignite just the stabilizer to see how flammable it is?
Budsjlm Sep 1, 2009 02:57 PM
did ya smell the stabilizer what that smell like
ChibiBlackSheep Sep 1, 2009 03:03 PM
What's your actual question?
Does the car smell like gas, is it the oil you drained out that smells like gas?
PINKFLOYD_ Sep 1, 2009 11:19 PM
The oil it's self smells like gas
03SS/00GSE/93LX Sep 2, 2009 12:00 PM
Used oil is always going to contain some gasoline that makes it's way into it. Used oil will almost always have a slight gasoline smell. Not really a big deal unless you're running really, really rich and the oil gets so much gas into it that it spins a bearing or causes another lubrication related issue- probably not the case here.
