FOUND COOLANT LEAK
Old Mar 15, 2008 | 07:10 PM
jay26's Avatar
Default FOUND COOLANT LEAK
its a 99 monte z34 it coming from the bottem of the radiator were the plug is,to drain the coolent correct me if im wrong.it looks like a easy fix,pop plug out coolant comes out put new plug in refill it?is this right?any thing else i shouldknow,precautions.thanks
Old Mar 15, 2008 | 08:02 PM
RocknSS04's Avatar
Default RE: FOUND COOLANT LEAK
Sounds correct, but with it being 9 years old, my guess is that it might be dripping there by the petcock, but it's not the petcock leaking, but a leak in the radiator. Is the radiator green around that area?
I hope I'm wrong!
Old Mar 16, 2008 | 02:24 AM
jay26's Avatar
what is the petcock wayne?i dont think its green i'll have to double check.if it is the petcock what does that mean?
Old Mar 16, 2008 | 06:37 AM
RocknSS04's Avatar
A petcock is a drain valve with a built in handle, like a wing nut. I'm assuming that there is one on the radiator, but honestly, I don't know for sure. Might just be a pipe plug. If it is a petcock, then you screw the **** in, not out, to open the valve.
Usually radiators get green when they die. That is where they leak. Altho, now that I think about it, that was partly due to the old green anti-freeze. HHHHMMMMM!
Petcocks or pipe plugs don't usually leak. The core of the radiator usually leaks, because of either rot or a hole in it.
Jalen
May 21, 2013 12:02 AM
MonteSquarlo
Dec 16, 2012 06:18 PM
01 Monte SS
Feb 9, 2012 12:22 AM
BlackRainSS
Aug 9, 2011 10:16 PM
greg fell
Jul 19, 2006 10:59 PM
