engine swap
Old Jan 9, 2009 | 10:46 PM
98monty's Avatar
Default engine swap
is there enough room in a 98 to fit a 3.8 supercharge engine out of the 6th gen modles? if so will it set a "SES" light or no from the other ecm that will go with the 3.8?
Old Jan 10, 2009 | 06:19 AM
RocknSS04's Avatar
Default RE: engine swap
It'll fit. Lotta work, but there are several here that have done the swap. Reprogramming the ECM will solve the SES or CEL light problems, and you have to do that anyways.
Old Jan 10, 2009 | 07:36 PM
You need to search, the L67 swap has been talked about quite a bit lately, and IMO, all the aspects are pretty completely covered- especially into a 5th gen monte.
Old Jan 16, 2009 | 05:47 PM
98monty's Avatar
what kind of mods?
Old Jan 17, 2009 | 07:11 PM
what are you asking- what mods do I have?
Old Jan 20, 2009 | 10:01 PM
98monty's Avatar
yea what kind of mods do u have ? not about an engine swap but on your monty.
Old Jan 20, 2009 | 10:15 PM
kweef's Avatar
not sure if this is completely accurate but heres a start
Engine Modifications: 9.5:1 forged pistons, balanced bottom end, IS3 blower cam w/ 1.7:1 aluminum roller rockers, ZZP S4 heads, ZZP ported LIM, ported blower and TB, electric WP, walbro FP, DPP headers, 4" intake, etc etc[/align] Brake, Suspension and Wheel Modifications: R1 concepts D/S rotors all around, R1 SS lines all around, EBC redstuff pads all around, GMPP front and rear strut bars, Held rear coilovers, BMR lateral and trailing arms, black powdercoated center piece[/align] Audio and Electronic Modifications: Pioneer Premier 730 deck, Earthquake 2200.4 4 channel, 8 Massive CK6 6.5"s speakers (4 up front, 2 rear, 2 in trunk lid), Earthquake D3 sub amp, 2 Atomic ELE 12"s in slot ported box, Audiocontrol line driver for sub amp.[/align] Interior Modifications: Fiberglass door panels, fiberglass center console w/ 7" tv-shaved cupholder-window switches relocated to it, fiberglass rear deck, other misc stuff[/align] Exterior Modifications: BK1 body kit, dominator hood, 18" Focal F5 chrome wheels, ebay black headlights, tint[/align]
Old Jan 21, 2009 | 03:53 PM
holy cow- you did some research huh?
Add to that list: 2.3L Whipple Supercharger, Yella Terra W/A IC, PRJ fuel rails, 65# injectors, Intense oil filter relocation kit
Subtract from that list: Pioneer deck, Earthquake amps, Atomic subs, driver's side door lock.... I think you understand what happened there... GRRRR
Old Jan 21, 2009 | 09:44 PM
kweef's Avatar
lol its not hard when ur a member of mm as well
Old Jan 21, 2009 | 11:12 PM
04superjr's Avatar
bumpin is there anywere i can see ur car?
