-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Engine shut off (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/engine-shut-off-38856/)
My_Monte Sep 13, 2012 09:30 AM
Engine shut off
2001 Monte - Engine shuts off after initial start. Also shuts off while driving and need to pop it into Neutral to start it up again.
Any thoughts on what it could be?
ChibiBlackSheep Sep 13, 2012 10:06 AM
3800 engine?
Try unplugging the MAF, or cleaning it with MAF spray.
Could also be a failing IAC
My_Monte Sep 13, 2012 12:52 PM
Yes...3.8
MAF?
IAC?
ChibiBlackSheep Sep 13, 2012 01:18 PM
They are all sensors on your Throttle Body
http://i33.photobucket.com/albums/d5...eep/iac_01.jpg
My_Monte Sep 13, 2012 01:56 PM
Thanks man.....that helps. Will probably start with the MAF and see how she responds.
ChibiBlackSheep Sep 13, 2012 01:58 PM
You'll need a T-20 Security Torx Bit to remove the screws :)
