Engine Coolant Fan Problem... HELP!!!!
I just realized the passenger side fan motor does not come on so I replaced the relay for that side and it still does not work. Could the relay that works both fans be bad even though the driver side fan is still working? Or what could be the problem...
HELP PLZZZZZ |
u could have a bad motor or a bad power/ground to that fan...hell even the fan control for that fan could b bad
