-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   dont know if i have transmisson problems or not (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/dont-know-if-i-have-transmisson-problems-not-40162/)
Lorenzo Nov 29, 2012 02:50 PM
okay so ive noticed that when im driving, going into overdrive the rpms seem to jump a bit. When im doing about 79 or 80 kmh and it shifts into overdrive, instead of dropping down to 1500rpm it goes up to about 2200-2300 then drops to 1600 then goes back up to about 1800-1900 then drops to 1500 and stays there. I have no hard shifts in any gears even when tranny is warm. Previous owner had the transmission rebuilt 6 years ago aswell. I found out that if i lift off the gas it will instantly drop to 1500 and i can go from there. There are no codes found other than the fuel level sensor. Hoping someone can shed some light on this :)
Johnboyp92 Nov 29, 2012 03:45 PM
sounds like its slipping, if the engine is running away
Lorenzo Nov 29, 2012 05:43 PM
well thing is when it does that the car is still accelerating so im not sure :p
Johnboyp92 Nov 30, 2012 12:52 AM
It still sounds like its slipping, or it could be some kind of sensor issue
STUMPMI Nov 30, 2012 05:40 AM
Check the TPS or the IAC before Id consider a trans issue...
I had a vehicle that was doing the very same thing...it turned out to be the TPS...
Yet it wasnt throwing any codes...
Lorenzo Nov 30, 2012 05:37 PM
Ok, how would i be able to check if the TPS or IAC are bad? Also if the TPS was bad wouldnt i be getting terrible mileage and bad throttle response? Im constantly getting 9.3-9.7 l/100km so im dong pretty well for gas mileage :)
STUMPMI Nov 30, 2012 10:40 PM
I too was still getting excellent fuel mileage..
Even the dealer couldnt figure it out....
I figured it out by happenstance..(process of elimination)
Just thought id pass the info along....
Try cleaning the TPS,... and reinstahl it...I ended up purchaseing a new TPS and problem solved...
Hope this helps!:)
