-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Difference between L36/L67 crank? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/difference-between-l36-l67-crank-17525/)
BUDDZZ Dec 11, 2009 11:13 PM
Just wondering if anybody know's if there is any difference between the cranks in the L36 and the L67?
Gib DTD Dec 12, 2009 01:01 AM
None that ive ever heard of, but there are many other differences in the engines. Pistons, Balance shafts, heads, push rods, intake manifold, harmonic balancer, and throttle body. The rest of the rotating assembly should be the same as the L36
bumpin96monte Dec 12, 2009 04:25 PM
Cranks are the same- obviously the rods are different also, wrist pin size is different on the L67.
Gib DTD Dec 13, 2009 04:21 PM
that I didn't know, thanks bumpin for enlightening me on that.
