Connecting Rods
Connecting Rods
i will be replacing the pistons on my LQ4 build to increase the compression. My question is should I just replace the conecting rods since it will be apart anyway? I also am not sure if i change them should I go with an I-beam or H-beam.
I guess it depends how high you plan to spin it, may be worthwhile to do stronger rod bolts if you're going to rev the heck out of it.
6th Gen ('00-'05): Heads and cam with turbo upgrade but stock pistons. opinons needed
godfather202
09-13-2014 04:58 PM
