codes
so i go into autozone today to see if they can read some ABS codes. yet some engine codes came up, this was weird because i have my bluetooth obd scantool and nothing was pending or came up.
well heres the codes, if anyone know what this might be let me know ABS CODES C1225, C1232, C1233, C1248, C1255 ENGINE CODES P1585, P1811, P1189 thanks in advance |
This is a known problem and there is/was a TSB 03-05-008 PIC3500
In short check the wiring harness it passes under/around the front of the transmission side cover. GM reports that harness chafing can occur in that area because the powertrain flexes on its mounts. Check the harness for any signs of chafing. Next, examine the area near the A/C dryer canister where the ABS harness splits. The harness can chafe right at the dryer canister bracket. If you find chafing, remove the harness and repair the damaged insulation with heat shrinkable tubing. After the repair you may have to reset/clear the ABS codes with a scanner, the engine codes also ...though the engine codes can be cleared with a NEG terminal disconnect. Advisable to clear all modules with a scanner as some will remain in them even the BCM |
bumperz
