Check Engine Light On --- Code P0742
Old Nov 29, 2013 | 08:11 PM
Joester16's Avatar
Default Check Engine Light On --- Code P0742
Hey guys.
I own a 2001 Monte SS and have developed a transmission issue.
About a month ago I was driving on the expressway and suddenly my check engine light came on and when I would press the accelerator or accelerating from a stop my car would jerk pretty bad. It did not stall out though when coming to a stop. I put a scanner up to it and got P0742 --- torque converter clutch circuit stuck on.
Fast forward to about a week and a half ago, it happens again. On the expressway the check engine light came on and same jerk when accelerating. My car now does it every 4 to 5 days.
The shop we took it too believes that the transmission is failing. After reading online there's a bit of conflicting information about it. My car doesn't stall out or my mileage hasn't been different which are the main symptoms of a bad solenoid.
So what's your guys' opinion? Thank you
Old Nov 29, 2013 | 09:22 PM
l67ss's Avatar
Hate to be the bearer of bad news but usualy if the tc stays locked the means the tranny is failing. The ecm will detect slippage and lock the tc as sort of a limp mode to get it home. Question, when was the last filter change on the transmission?
Old Nov 30, 2013 | 12:11 AM
Joester16's Avatar
I have not changed the filter since I've had the car. Got it at 109k and now at 134k.
Old Nov 30, 2013 | 01:27 PM
l67ss's Avatar
Id try that first
Old Dec 2, 2013 | 11:48 AM
Celina Wakley's Avatar
Default check engine code
Hey you might be in problem, check engine Code P0742 online.
codyswanson4
Jul 8, 2015 11:10 PM
StrongTakeover
Sep 26, 2011 08:44 PM
Ds 01 MC
Aug 20, 2008 05:58 PM
Suppoko
Apr 24, 2008 06:30 AM
Bigg J
May 17, 2007 06:48 PM
