Originally Posted by WolvenScout
(Post 715725)
I'm also going to have the engine rebuilt with new bearings, rods and pistons to bring the compression down, and a cam.
There are a couple issues with low compression, the biggest issue is that it makes the engine a complete dog out of boost. These engines dont make squat for power as it is NA, dropping compression and sticking in an aftermarket cam will make that even worse driving around. It's one thing in a drag only car with a loose converter and a brake, but it sure sucks on the street. Just leave the bottom end how it is and run e85 or just hit it with meth. |
(Post 715731)
Why would you want to bring compression down?
(Post 715732)
Doesn't lowering the compression make it safer to run higher boost?
I plan on driving the car often, and the thing with E85 is, it's not too common in my area. With meth, is there an easy way to run it only when higher power is needed, and not run it while just driving down the street? |
(Post 715733)
That's the beauty of a meth injection kit. It only injects when the boost exceeds the Hobbs switch limit. So 99% of the time on the street, it wont run at all. Get into boost, and you've suddenly got extra octane. I run a kit on my vette and love.
(Post 715734)
Would the AEM meth kit zzp sells be a good option?
The kit I run on my vette is an Alkycontrol, but that's just because theyve got a lot of support for that community. |
(Post 715747)
Sounds good on paper, but I've never personally run one so I can't comment specifically.
