Automatic Transmission Info
Gear Ratios of Popular GM Transmissions
Trans 1st Gear 2nd Gear 3rd Gear 4th Gear Reverse Powerglide 1.76/1.82 1.00 --- --- 1.76/1.82 TH350 2.52 1.52 1.00 --- 1.94 TH400 2.48 1.48 1.00 --- 2.07 TH200-4R 2.74 1.57 1.00 0.67 2.06 TH700-R4 3.06 1.62 1.00 0.70 2.29 4L80E 2.43 1.49 1.00 0.75 2.07 http://www.maliburacing.com/tranny_i...guidelines.jpg http://www.maliburacing.com/tranny_i...dimensions.jpg http://www.maliburacing.com/tranny_id/auto/pan_id.jpg 1 Aluminum Powerglide 14 bolts 2 TH200 Metric 11 bolts 3 TH350 13 bolts 4 TH400 13 bolts 5 TH200-4R 16 bolts 6 TH700-R4, 4L60, 4L60E 16 bolts 7 4L80E 17 bolts Identifying a TH200-4R vs. TH200 http://www.maliburacing.com/tranny_id/auto/2004r.jpg Photo of TH200-4R transmission The TH200-4R is identified by 10 bolt holes and 2 dowel-pin locator holes on the universal bellhousing. It has a dual bolt pattern for both Chevrolet and BOP (Buick, Olds, Pontiac) applications. The TH200 has only six bolt holes and 2 dowel-pin holes |
