Anyone use larger oil filter for 3800?
Hi everyone,
I'm wondering if there is any advantage running a longer oil filter on the 3800. the stock PF47 oil filter is 3.3" high. I found a Wix filter with same diameter and threads, but is 4.825 long. Looks like plenty of room to fit an extra 1.5 inches, not sure how much oil that would actually hold, but it may help in cooling the oil... has anyone tried this filter? Might allow the 3800 to hold 5 quarts instead of the 4.5 for the standard filter. I hate having to pour 4.5 quarts of oil out of a 5 quart jug and try to keep the last half quart in the jug. Here is the Wix 51036 filter specs: https://www.rockauto.com/en/moreinfo...360547&jsn=360 |
Originally Posted by DAVESS2002
(Post 705573)
Hi everyone,
Good question. There is one member, Turbo Monte who is running a larger oil filter on his 3800. Do not recall the actual size or part number. Perhaps he will see this and chime in as to the actual filter he uses.
I tried with his information but the oil filter adapter on mine unfortunately took up the extra space so I'm stuck using the OEM recommended size. Like Drivernumber3 states WIX is a highly reputable brand. I use the AMSOIL filter and their 15-50 race oil. They also sell WIX on their website as an alternate filter. |
A PF52 will fit and is maybe 3/4" longer. I can't imagine it'll hold half a quart extra though. I also can't see it cooling the oil any better. Sounds like an oil cooler would do what you're looking for.
Honestly I never really understood the benefit to running a larger filter as long as you change your oil frequently. The filter media is likely the same, so it won't physically filter any better, it'll just let you go longer between oil changes as it'll take longer to plug up. I don't push my oil changes anyways, just not worth the risk to me to damage an engine for $25. |
Isnt it the 7th gen v8's filter that can be put onto a 3800??
(Post 705609)
(Post 705603)
Honestly I never really understood the benefit to running a larger filter as long as you change your oil frequently. The filter media is likely the same, so it won't physically filter any better, it'll just let you go longer between oil changes as it'll take longer to plug up. I don't push my oil changes anyways, just not worth the risk to me to damage an engine for $25. I agree :thumbsup: |
(Post 705619)
No, the LS4 uses a PF48. Larger center opening, different thread, and about the same height as a PF47. That would be far too much hassle to make work for basically no benefit.
I use a pf52. If it can fit safely why not have the extra protection or atleast piece of mind even if it doesn't do anything.
(Post 705664)
But as I mentioned I had issues with a larger one, so now I try to run the absolute best for the peace of mind you speak of. :thumbsup: |
