6th Gen ('00-'05): Anyone use larger oil filter for 3800?
-Different oil filter adapter
-Different types of subframe
-Different type of motor mounts
Add to that the variables of how worn the motor mounts are and how much power the engine makes (ie how much it rocks around) and that clearance can get pretty tight with a longer filter. No doubt it's a rare occurrence compared to the number of people running them, but a few people have hit the longer oil filter on the cradle.
Since the stock filter setup has proven just fine from high hp cars to daily drivers with hundreds of thousands of miles, I just don't see the benefit in messing with it. It doesn't really offer any proven better filtering capability and if you do happen to plug up a PF47 within the normal OCI, the engine is already toast anyways to be releasing that much debris (blow by or bearing pieces).
If the goal really is to get a better filter on there, there is an aftermarket adapter made to allow you to remote mount whatever type of filter you want. Or course it requires external lines to connect that, so that certainly comes at its own risk as well (leaking fittings, blown lines, etc) but it could be made as reliable as stock if done correctly.
Just an update, last oil change I tried the PF52 longer oil filter. It looked like it would fit, but due to the angle of the oil filter adapter, I could not angle the filter enough to line up the hole with the threads. the bottom corner of the filter hit the frame, so it's a no-go. Keep on using the stock filter is the only option for now.
Thanks
Dave
Thanks
Dave
