84
How is the locking torque converter set up on the 84 model? I also need to know which fuse is connected to the torque converter. Thanks for any help guys!:confused:
Welcome to the Monte Carlo Family...
Please check back to see if any of our expert tech member's can assist.. Also, check out the below link: https://montecarloforum.com/forum/fo...4th-gen-22070/ :rolleyes: Click above & Good Luck |
If I'm not mistaken, 84 came with TH-350. It's different from 200-4R, so be careful. Most of the tech write up are for 200-4R.
Also, what fuse are you talking about? Lock-up are controlled by ECM computer. I don't remember having any fuse. |
