-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   2nd Broken Flex Plate (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/2nd-broken-flex-plate-7370/)
BeachBumMike Jan 13, 2008 04:29 PM
RE: suspicion confirmed
Hi Wayne, sorry to read about your problems, & your pastor.
Unfortunately, machines & human break : (
I hope that both can be repaired successfully.
I pray for all, that are in pain.
There are so many.
We are so fortunate, `if we are not......in pain.
I will do some reseach on problems with the GM Flex Plate, and post `if I find.
I do know that my racing friends always have the balanced check on their
flywheel & converter. My one friend had a B&M Trans that kept on blowing/break'in
until he had it balanced.
I hope that your problem can be covered under your GM Warranty,
or that you can find a decent price for parts/repair.
Good Luck `Wayne
GrandPaDave Jan 13, 2008 06:05 PM
Unless they have the capability to do a catscan on the plates before they are installed, shiznick like that happens when you are going for performance.
Like I've said before, torque converter are very simple mechanical devices.
ExplosiveSoundz Jan 14, 2008 03:12 AM
Confirmed what I thought I was hearing, a broken flex plate.
Can you describe, in a nutshell, what it SOUNDS like? I am curious as to whether or not maybe that is what caused my tranny issue and improper gear ratio code last week....
RocknSS04 Jan 14, 2008 04:49 AM
It sounds like a loose fan blade rattling, especially at idle with no pressure on it. No noise under throttle until it is about to let loose.
BeachBumMike Jan 14, 2008 05:15 AM
[align=center]Hi Wayne,[/align][align=center][/align][align=center]I found the below TSB for 05 Impala[/align][align=center]TSB #03112005 -- TICK OR KNOCK NOISE FROM THE TORQUE CONVERTER FLYWHEEL FLEX PLATE. *EH (NHTSA ID #10014861, MARCH 11 2005[/align][align=center]
POWER TRAIN:AUTOMATIC TRANSMISSION:TORQUE CONVERTER
[ul][*]TSB #3365A -- TICKING OR KNOCKING NOISE CRACKED OR BROKEN FLEXPLATE. VARIOUS MODELS INCLUDI[/ul][/align][align=center]Click on below link for more TSB [/align][align=center][:-][/align][align=center]http://www.carcomplaints.com/Chevrol...005/tsbs.shtml[/align][align=center][/align]
[hr]
[align=center][/align][align=center]I will continue to search, and contact my automotive sources,[/align][align=center]for information.[/align][align=center]Good Luck `Wayne[/align][align=center][/align][align=center][/align]
RocknSS04 Jan 14, 2008 07:37 PM
I ordered parts today from ZZPerformance. Talked to Tim. He said that the next thing to go will be the transmission input shaft unless I change the torque convertor to a lighter unit, ie, theirs. I trust them, so I bought a new 2500rpm stall torque convertor along with the Meziere flex plate. Total including shopping, just undet $870.
ZZP is saying, unless I'm misunderstanding, that this convertor will shave 1/2 second of my 1/4 mile time, with only this mod. They are EIGHT pounds lighter than stock!
https://www.zzperformance.com/products_img/133_1.jpg
Link:
https://www.zzperformance.com/grand_...&catid=105
Cost of labor in this project to be between $520 and $600 depending on who I have do the install. So there goes my intercooler money, but maybe this is for the best, if it saves my transmission, at least for a while.
ExplosiveSoundz Jan 14, 2008 08:01 PM
You're right. They help, considerably. But don't you have to drop the tranny to install the converter? Please let me know how that goes Wayne! =) I'm excited for you! Glad you turned lemons into lemonade.
04 Intimidator Jan 14, 2008 11:28 PM
ORIGINAL: RocknSS04
HOLY SH!T!!! That is awesome!!!! Definately worth it for a full 1/2 second.
RocknSS04 Jan 15, 2008 04:25 AM
Yes to dropping the tranny, but the motor stays in. Been there, done that once before. That's why the $575 to install. I'm also doing another tranny service, changing the filter and switching to Dextron IV, per ZZPerformance.
If this is true about the 1/2 second, yes, I DID just turn lemons into lemonade:). I don't feel quite so bad about spending the $1,500 if it helps the performance THAT much.
Going to do a full service, too: rotate tires and oil change. Thursday, it looks like.
Still looking at installing the intercooler, roller rockers, pipes, and dyno tuning this spring. Then it will be time for a RACE trans', because this one will probably go BOOM!
BeachBumMike Jan 15, 2008 05:00 AM
Hi Wayne,
Please keep up updated on your progress. It's great that you have the tools, and
experience to work on your own car. Can't wait for the completion, and to
hear about the difference that your modifications make.
I can visualize your Monte lined `up against Lucy : ) :D[:o]
Look forward to your future posts.
Wish you good luck and a easy install.
Peace/Out
`Space
